Home > Maintenance & Modifications > Dual battery and fuse box
bear100
Well the time has come for me to fit a split charge system in preparation for my overland trips Very Happy
At the moment i plan to use the National Luna set up, looks very good quality and has a controller to use manually with visual and audible alarms etc. but they are quite expensive
Battery wise I'm not entirely sure what to go for? Optima was top of my list until i saw the Odysseys, i have also heard that the Optimas are not fussed on full discharge and recharge cycles? my defender will be used extensively on the overland trips running a fridge, various lights, charging phones and tablets etc, but it will also be parked up for a week or two most of the time with little use. don't want to kill the optima Neutral
I also need to fit a Bluesea fusebox and hopping to fit it all under the passenger seat Shocked
Can you shoe me what you have done and how it all works for you Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #776717 8th Jun 2019 6:00pm
landy andy
I’ve run Odyssey’s for ages. Find them great batteries. Used and abused. Once a year disconnect them and put a ctek charger on and that’s it.
Post #776783 9th Jun 2019 9:13am
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Either batteries are ok even a normal agm will do the job .The trick is to put back what you take out quickly, so charging system prob more important that battery type . Get a good dc dc charging system like red arc or ctek with smart pass think national luna now do dc to dc system too, then pop a solar panel on system , 200wat if you can .
If however you don’t use much power a normal tmax / durite solenoid switch and large solar with mppt will cope. 👍
Work out how many amps you will draw per hour then select charging system that can deliver it ,
Good agm or gell battery with dc -dc and solar is the fit and forget option . Have fun be happy
Post #776785 9th Jun 2019 9:51am
