![]() | Home > Technical > 04 110 XS TC Issues |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
I had a similar issue with my Disco 2 after fitting new front axle ball joints. The n/s sensor was giving an "intermittent output" which clearly fooled the SLABS ECU into thinking that the wheel was rotating slower than the others, so it braked the other three wheels. Since this did nothing to solve the problem, it braked harder and harder. After about 3 times it figured there was a fault and disabled itself. Changing both sensors solved the issue.
It could be a faulty sensor, incorrect gap, defective inductor ring, or bad connection. |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Rings are clean. Sensors are new. The fronts are working propeely as far as i can tell. So must be the rears juat dont know how to set the air gap!
What faults does the Nanocom give? Also worth checking the individual wheel outputs with Nanocom (assuming you can do this on a Defender) to narrow it down.
I was fooled by my first edition WSM for the Disco saying clearly that the sensors can be removed and refitted with no problems. I later discovered that the second edition says that they must not under any circumstances be removed from the hubs, and if a new is needed then a whole new hub assembly must be fitted. |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
As far as I was aware there is no adjustment in setting the gap? The sensors just push all the way 'home' as it were?
Is the copper bush ok? Maybe a daft suggestion but if the old one was tight coming out, has the new one definitely gone all way down? > 110 XS Double Cab |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
The sensors self-adjust and should be pushed all the way in until they contact the ring.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
Righto ill push them in a little further then.
Nancom gave rear right sensor electrical failure - cleaned it all up, cleared the code returned instantly. Tried 3 times hence new sensors. The rear left was seized solid in place and had to be knocked put from the disc side. New copper bush installed. Rear right came out with reasonable ease and new sensor push in. Though surely if i push too far they will touch the ring and grind off? |
Nope they get pushed out.
2015 D90 XS SW |
Even on the rears?
Ill push them in, jack it up and spin by hand carefully! Thanks chaps |
This piqued my interest...
https://www.landyzone.co.uk/land-rover/abs-sensor-air-gap.214807/ suggests they will 'self gap' What was the error code? This is also interesting https://landroverforums.com/forum/discover...sis-11257/ > 110 XS Double Cab |
Thanks for the help chaps. Appear to have fixed it. Gave each sensor a knock in with a drift mallet and no more issues, at least in the past 100 miles.
Good news
2015 D90 XS SW |
| All times are GMT |
