Home > Technical > 04 110 XS TC Issues
bankz5152
04 110 XS TC Issues
So the Nanocom has been telling me the rear right ABS sensor has been failing so bought some Intermotor replacements.
Changed them over today which was a right pain as one of the sensors was full seized in in place! Had to pull the hub off and push it out.
Eventually replaced them (left and right) but the TC is going mad now, engaged as soon as I pulled off the drive, then turned off. Kicked in again very harshly and pulled the whole 110 right!
At the minute the TC is turned off. Any reason why this has happened? A mate suggested it could be an air gap issue. If so how does one set the gap? Instagram @defender_ventures
Empire Tuning - Agent
Post #775209 27th May 2019 7:33pm
I had a similar issue with my Disco 2 after fitting new front axle ball joints. The n/s sensor was giving an "intermittent output" which clearly fooled the SLABS ECU into thinking that the wheel was rotating slower than the others, so it braked the other three wheels. Since this did nothing to solve the problem, it braked harder and harder. After about 3 times it figured there was a fault and disabled itself. Changing both sensors solved the issue.
It could be a faulty sensor, incorrect gap, defective inductor ring, or bad connection.
Post #775232 27th May 2019 10:13pm
bankz5152
Rings are clean. Sensors are new. The fronts are working propeely as far as i can tell. So must be the rears juat dont know how to set the air gap! Instagram @defender_ventures
Post #775250 28th May 2019 6:14am
What faults does the Nanocom give? Also worth checking the individual wheel outputs with Nanocom (assuming you can do this on a Defender) to narrow it down.
I was fooled by my first edition WSM for the Disco saying clearly that the sensors can be removed and refitted with no problems. I later discovered that the second edition says that they must not under any circumstances be removed from the hubs, and if a new is needed then a whole new hub assembly must be fitted.
Post #775254 28th May 2019 7:35am
hank
As far as I was aware there is no adjustment in setting the gap? The sensors just push all the way 'home' as it were?
Is the copper bush ok? Maybe a daft suggestion but if the old one was tight coming out, has the new one definitely gone all way down? > 110 XS Double Cab
> Instagram @simonlanemind
Post #775255 28th May 2019 7:54am
Martin
Site Admin
The sensors self-adjust and should be pushed all the way in until they contact the ring.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #775272 28th May 2019 10:48am
bankz5152
Righto ill push them in a little further then.
Nancom gave rear right sensor electrical failure - cleaned it all up, cleared the code returned instantly. Tried 3 times hence new sensors.
The rear left was seized solid in place and had to be knocked put from the disc side. New copper bush installed.
Rear right came out with reasonable ease and new sensor push in.
Though surely if i push too far they will touch the ring and grind off? Instagram @defender_ventures
Post #775275 28th May 2019 10:55am
Martin
Site Admin
Nope they get pushed out.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #775276 28th May 2019 10:57am
bankz5152
Even on the rears?
Ill push them in, jack it up and spin by hand carefully!
Thanks chaps Smile Instagram @defender_ventures
Post #775277 28th May 2019 11:11am
hank
This piqued my interest...
https://www.landyzone.co.uk/land-rover/abs-sensor-air-gap.214807/ suggests they will 'self gap'
What was the error code? This is also interesting https://landroverforums.com/forum/discover...sis-11257/ > 110 XS Double Cab
Post #775295 28th May 2019 1:59pm
bankz5152
Thanks for the help chaps. Appear to have fixed it. Gave each sensor a knock in with a drift mallet and no more issues, at least in the past 100 miles. Instagram @defender_ventures
Post #775670 31st May 2019 10:27am
Martin
Site Admin
Good news Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #775673 31st May 2019 11:00am
