![]() | Home > Maintenance & Modifications > Idea for headlining mounted grab handle. |
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4319
Above and just behind the front seats there is a join in the headlining running the full width. It’s secured with fir tree clips. Does anyone know is could remove two of the fir trees and secure a grab handle like this https://www.mudstuff.co.uk/products/mud-st...andle.html ?
Is there something solid behind there to mount to and could I screw into the existing fir tree hole/grommet/bush things to avoid making any new holes and keeping things reversible? 2007 110 TDCi Station Wagon XS |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
The existing fir tree holes are pretty big - maybe 4-5mm diameter. You could drill them out put rivnuts in them though, which would give a reasonably solid fixing. I've seen some folks secure their headlining in that manner. Darren
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2383
Bluest,
You could use a couple of m6 speed clips, clipped to the inner gutter to screw into. https://www.amazon.co.uk/PACK-CHIMNEY-NUTS...B075YTLFVV Be careful of the rear washer pipe which runs along the inside of the gutter ! HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5136
There is this option as well from Bolt on Bits that you could adapt.
Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Are there some existing holes there that I can use, or will I need to drill? 2007 110 TDCi Station Wagon XS |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
There are no other holes, so if you want other holes than the fir tree ones you need to drill. a defender from 1984 pretending to be a puma with a touch of Range Rover
