Home > Maintenance & Modifications > Idea for headlining mounted grab handle.
Bluest
Above and just behind the front seats there is a join in the headlining running the full width. It’s secured with fir tree clips. Does anyone know is could remove two of the fir trees and secure a grab handle like this https://www.mudstuff.co.uk/products/mud-st...andle.html ?
Is there something solid behind there to mount to and could I screw into the existing fir tree hole/grommet/bush things to avoid making any new holes and keeping things reversible? 2007 110 TDCi Station Wagon XS
Post #775178 27th May 2019 12:11pm
The existing fir tree holes are pretty big - maybe 4-5mm diameter. You could drill them out put rivnuts in them though, which would give a reasonably solid fixing. I've seen some folks secure their headlining in that manner. Darren
Post #775188 27th May 2019 2:29pm
Mo Murphy
Bluest,
You could use a couple of m6 speed clips, clipped to the inner gutter to screw into.
https://www.amazon.co.uk/PACK-CHIMNEY-NUTS...B075YTLFVV
Be careful of the rear washer pipe which runs along the inside of the gutter !
HTH
50 Shades of Pennine Grey
Post #775190 27th May 2019 3:15pm
gilarion
There is this option as well from Bolt on Bits that you could adapt.
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #775191 27th May 2019 3:28pm
Bluest
Mo Murphy wrote:
Bluest,
HTH
Mo
Are there some existing holes there that I can use, or will I need to drill? 2007 110 TDCi Station Wagon XS
Post #775208 27th May 2019 7:21pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
There are no other holes, so if you want other holes than the fir tree ones you need to drill. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #775220 27th May 2019 8:53pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
That is what I’d do. I fitted a roof mounted DVD player for the kids in this manner. Worked a treat. 2002 110 td5
Post #775229 27th May 2019 10:02pm
