Home > Td5 > another strange starting problem |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5417 |
Starter solenoid
27th May 2019 8:09am |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 822 |
Single click = Solonoid
Multiple clicks = Voltage I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
27th May 2019 10:05am |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 163 |
there is no click from the starter nobody is perfect but being Scottish is a start
27th May 2019 12:21pm |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 509 |
Try a positive feed from battery direct to starter motor spade terminal, to check if starter motor or wiring
27th May 2019 12:32pm |
age of starting battery ? and have you had it tested
27th May 2019 1:47pm |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
my bets are on a rusty crusty earth
27th May 2019 2:00pm |
Take the starter out, clean it and put new contacts in the soloniod. Also clean de inside off the starter gearbox and put new grease there. It will run a lot better. Roel
27th May 2019 6:49pm |
hopefully got it fixed, the starter wire on the solenoid was a loose fit and grubby, cleaned the terminal on the starter and put a new crimp on and it has been ok since, what i dont get is why when i let it roll back it would start. nobody is perfect but being Scottish is a start
29th May 2019 6:14pm |
