Home > Puma (Tdci) > Which oil filter? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4475 |
If it is the spin on type this would be it
https://www.advancedfactors.co.uk/lr058104...3255-p.asp If it's the paper type I use this https://www.advancedfactors.co.uk/lr030778...3111-p.asp Both from Advanced Factors https://www.advancedfactors.co.uk/service-...-210-c.asp The above are from the service items listed for the 2.2 engine 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
26th May 2019 12:23pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3009 |
Thanks for your reply.
Yes the new engine uses a spin on filter. I’m hoping the type Land Rover use for the 2.2 will be OK for my 2.4. Is there any reason this may not be the case? |
26th May 2019 12:33pm |
There is only one type of spin on metal filter listed so that should be it. I use Mahle filters and there is a Mahle spin on type listed on the advanced Factor site. https://www.advancedfactors.co.uk/lr104384...8843-p.asp
If you are still unsure e-mail Advanced Factors. They are a site sponsor and will give you a discount for being a member of Defender2. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
26th May 2019 12:44pm |
Thanks for that. I had mentioned it to another site sponsor but they didn't know. I'll give AF a shout.
26th May 2019 4:28pm |
