Home > Puma (Tdci) > Idle jack not working?
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
For some reason the idle jack isn't kicking in. Anti-stall works fine with the engine running at 750 rpm but I'm fairly sure it used to run at 950 going up to 1100.
Any ideas?
It's a 2010 110
Post #774488 22nd May 2019 10:14pm
In high or low? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #774495 22nd May 2019 10:54pm
Zed
In high. Only noticed it when I was stuck in traffic. Haven’t tried low range yet.
Post #774503 23rd May 2019 6:02am
jst
Idle Jack is a low range feature. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #774511 23rd May 2019 7:21am
nicam
2015 Defender 110 Puma 2.2 USW Aintree Green
Idle Jack? - I think I used to work with him! Don`t drive faster than your angel can fly!
Post #774526 23rd May 2019 10:03am
Zed
Oh. Didn’t know that. Well it used to work in high for me and was very helpful in traffic.
Post #774536 23rd May 2019 11:13am
^^ In that case you had a fault which has now gone away!
Idle jack is definitely only active in low range. Anti-stall is active all the time when there is no throttle input in either range.
Post #774557 23rd May 2019 2:24pm
Zed
I’m gonna take that as a win!
Thanks chaps.
Post #774571 23rd May 2019 5:05pm
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
Hmmm.... don't know that I agree that idle jack in a low-range-only feature... or that then means my car has a fault too! Very Happy
My idle speed increases by around 100 or 200 RPM in high range if the car is moving more than snails pace. MY10 2.4 Puma.
Post #774655 24th May 2019 8:37am
bear100
ummmm what is an idle jack Confused 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #774658 24th May 2019 8:54am
skidrov
My interpretation is "your engine idle speed increases by around 100 or 200 RPM once the vehicle is moving more than a snail's pace". To use layman's terms.... Smile
Post #774661 24th May 2019 8:57am
Bluest
Mine has a very small idle jack in high range. As soon as the car rolls the idle rpm lifts ever so slightly. Nothing like as much as low range but it is definitely there. 2007 110 TDCi Station Wagon XS
Post #774662 24th May 2019 9:03am
dorsetsmith
Check your transfer ratio switch wiring and switch
Post #774663 24th May 2019 9:06am
