![]() | Home > Puma (Tdci) > Idle jack not working? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
In high or low? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
In high. Only noticed it when I was stuck in traffic. Haven’t tried low range yet.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
Idle Jack is a low range feature. Cheers
nicam Member Since: 14 Dec 2007 Location: deepest Lancashire Posts: 159 ![]() ![]() |
Idle Jack? - I think I used to work with him! Don`t drive faster than your angel can fly!
Oh. Didn’t know that. Well it used to work in high for me and was very helpful in traffic. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
^^ In that case you had a fault which has now gone away!
Idle jack is definitely only active in low range. Anti-stall is active all the time when there is no throttle input in either range. |
I’m gonna take that as a win!
Thanks chaps. |
skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 56 ![]() ![]() ![]() |
Hmmm.... don't know that I agree that idle jack in a low-range-only feature... or that then means my car has a fault too!
![]() My idle speed increases by around 100 or 200 RPM in high range if the car is moving more than snails pace. MY10 2.4 Puma. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
ummmm what is an idle jack
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
My interpretation is "your engine idle speed increases by around 100 or 200 RPM once the vehicle is moving more than a snail's pace". To use layman's terms....
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4330 ![]() ![]() ![]() |
Mine has a very small idle jack in high range. As soon as the car rolls the idle rpm lifts ever so slightly. Nothing like as much as low range but it is definitely there. 2007 110 TDCi Station Wagon XS
Check your transfer ratio switch wiring and switch
