Home > Puma (Tdci) > Puma 2.2 Temp Gauge Rise and power loss
HSnow90
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Indus Silver
Hello!
Really hoping someone can help, new to owning a Tdci 2.2, used to have a 300tdi so I’m completely lost Big Cry
Tonight after a cold start about 5 miles down the road, 40/50mph I lost all power and noticed the temp in the red, nearly died of panicking overheating and blowing the head! However almost as soon as it was slowing down due to power loss the temp came back to normal and power restored, no warning lights etc and after taking it out again to get a video, I’ve learnt turning the engine off when the temp is in the red, and straight on again it restores the power instantly, almost resting something that’s failing? The fan when in the red when I pulled over was going like a maniac,
Video on YouTube -
If that doesn’t work search: Puma 2.2 Temp Rise power loss
Really hoping something simply like a relay or temp sensor maybe? Fault repeats itself at slower speeds, seemed ok at motorway speeds,
Apologies for bad grammar and spelling! and thank you in advance Bow down
Harry
Post #774460 22nd May 2019 8:50pm
bear100
I had a similar issue on my 2.4 which turned out to be the ECT engine coolant sensor reading incorrectly, one give away was when i turn on the ignition from cold the temp gauge would rise slightly, may be worth a try.
Also do the heaters go cold? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #774468 22nd May 2019 9:16pm
HSnow90
Ok might give that one a go, or at least have a look at it
Yea heaters blow cold still,
Post #774474 22nd May 2019 9:33pm
Co1
Sounds like dodgy sensor as already mentioned. Cheap place to start as well.
Post #774504 23rd May 2019 6:11am
HSnow90
I noticed the coolant wasn’t up to the cold level, infact not even in the header tank, so topped that up per the workshop manual and it was giving off a bit of grey blue smoke, so it’s on a trailer to the garage! a better safe than sorry later on!
Post #774718 24th May 2019 2:50pm
Stacey007
Mine did this 2.4...
I have a ultra gauge and temp sits at 85 / 89 all day long normally.
It creeped up and up one day on the way to work (it was a hot day) and engine went into limp mode. I kept stopping to make it to garage, at one point I saw 114 Big Cry
Anyway topped up with collant and was fixed the following day, a temperature valve. Genuine part around £80 and its sorted,
Bit unnerving though when it just doesn't want to go
Post #774721 24th May 2019 3:18pm
HSnow90
So it turned out to be the head Big Cry
New head going on etc hopefully it will be sorted! Was hoping it wasn’t the expensive option but glad I got it trailered to the garage!
Post #776395 6th Jun 2019 6:50pm
Julie
That's really bad luck. Do you tell us your mileage ?
Post #776410 6th Jun 2019 8:25pm
HSnow90
Yea I know!
Erm think around 73,000-75000, completely standard engine wise, no map etc think I’ve just been unlucky!
Post #776421 6th Jun 2019 8:59pm
