![]() | Home > Technical > LED lights not blinking with remote door lock |
| PCM Member Since: 25 Jan 2019 Location: North East Posts: 895
It's an annoyance, but not a massive issue.
When i lock the vehicle, before I changed the incandescent bulbs to LED, they used to blink. Not so with the LED ones. Mostly bearmack and nakantanenga. (Bearmach LED relay) Does anyone else have this issue? Is it common and if so what LEDs blink and what just stay off. I May change them, I may just grumble a bit. |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Mine work ok.
Are you sure it’s not just your remote battery getting flat? |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
Do they flash on unlock?
1988 90 Td5 NAS soft top
2015 D90 XS SW |
Nope. Not a single flash on unlock or lock
Have 2 remotes and both have decent battery. The lights work perfectly normally in all other ways. All are quite new with the led relay. I thought it'd be a common issue. |
Have you fitted a adjustable flash relay to replace the standard item?
The relay is a standard led unit with the Bearmach kit.
The indicators work which is confusing the heck out of me. I’ll check hazards, but assuming they do too. Surely this means the led relay is fine? I’ve seen the relays with adjustment on them, but this isn’t mine. Where are they from? |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
No suggestions from me sorry but if it's any help I have RDX LED's with RDX relay and mine flash ok on lock/unlock > 110 XS Double Cab
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
check fuse supplying alarm unit
Possibly.
Does anyone have a fuse list for the puma 2.2. Is this one under the dash or seat box? Are they the same for the 2.2 as they are for the 2.4? https://www.lrworkshop.com/electrics/defen...nd-headers I'm struggling to think if they (LED) ever worked with the central lock or just recently. |
Finally managed to track the problem down.
Turns out someone did a security mod to stop the side indicator short from disabling the imobiliser. But they had done so in a way as to use stotchlock inline fuse holders that had wiggled loose on one side and blown a fuse on the other. They tried to do a good thing. But did it cheaply. I love this car. Just wonder what I'm going to find next. Cheers for all the suggestions. No-one could have foreseen what i found. PCM |
| Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285
A wise old Landrover owner once told me
"Do not bother fixing it, something bigger will only break next time if you do" 2008 Defender 110 XS CSW Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
Shorting the indicators will not disable the immobiliser, but will disable the alarm on vehicles of a certain age which have not had the mod to prevent this from happening applied. |
| All times are GMT |
