Home > Technical > LED lights not blinking with remote door lock
PCM
It's an annoyance, but not a massive issue.
When i lock the vehicle, before I changed the incandescent bulbs to LED, they used to blink.
Not so with the LED ones. Mostly bearmack and nakantanenga. (Bearmach LED relay)
Does anyone else have this issue? Is it common and if so what LEDs blink and what just stay off.
I May change them, I may just grumble a bit.
Post #772546 10th May 2019 8:28pm
landy andy
Mine work ok.
Are you sure it’s not just your remote battery getting flat?
Post #772555 10th May 2019 9:50pm
Martin
Site Admin
Do they flash on unlock?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #772557 10th May 2019 9:56pm
PCM
Nope. Not a single flash on unlock or lock
Have 2 remotes and both have decent battery.
The lights work perfectly normally in all other ways. All are quite new with the led relay. I thought it'd be a common issue.
Post #772566 10th May 2019 11:29pm
landy andy
Have you fitted a adjustable flash relay to replace the standard item?
Post #772572 11th May 2019 5:08am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Do they flash when you press the hazard switch, check the adjustment on the relay mine has a small adjuster pot on it. I believe the correct setting is to put the hazards on then adjust it until the trailer light comes on, then back it off a bit until it just goes out. 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #772583 11th May 2019 5:52am
PCM
The relay is a standard led unit with the Bearmach kit.
The indicators work which is confusing the heck out of me. I’ll check hazards, but assuming they do too.
Surely this means the led relay is fine? I’ve seen the relays with adjustment on them, but this isn’t mine. Where are they from?
Post #772592 11th May 2019 8:15am
hank
No suggestions from me sorry but if it's any help I have RDX LED's with RDX relay and mine flash ok on lock/unlock > 110 XS Double Cab
Post #772595 11th May 2019 8:27am
dorsetsmith
check fuse supplying alarm unit Exclamation
Post #772599 11th May 2019 8:53am
PCM
Possibly.
Does anyone have a fuse list for the puma 2.2. Is this one under the dash or seat box?
Are they the same for the 2.2 as they are for the 2.4?
https://www.lrworkshop.com/electrics/defen...nd-headers
I'm struggling to think if they (LED) ever worked with the central lock or just recently.
Post #772649 11th May 2019 5:51pm
PCM
Finally managed to track the problem down.
Turns out someone did a security mod to stop the side indicator short from disabling the imobiliser.
But they had done so in a way as to use stotchlock inline fuse holders that had wiggled loose on one side and blown a fuse on the other.
They tried to do a good thing. But did it cheaply.
I love this car. Just wonder what I'm going to find next.
Cheers for all the suggestions. No-one could have foreseen what i found.
PCM
Post #778304 20th Jun 2019 6:55pm
Swollock
A wise old Landrover owner once told me
"Do not bother fixing it, something bigger will only break next time if you do" 2008 Defender 110 XS CSW
Volvo XC40 Recharge
Triumph T120
BMW R1300GS
G0UBX
Post #778379 21st Jun 2019 9:26am
Shorting the indicators will not disable the immobiliser, but will disable the alarm on vehicles of a certain age which have not had the mod to prevent this from happening applied.
Post #778381 21st Jun 2019 9:34am
