![]() | Home > Maintenance & Modifications > Self cancelling indicators don't work |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
You're missing the pins. Guess your steering wheel is from one of the last Defenders.
edit: no need for a new steering wheel. You could drill to small holes in the rear and smash some hollow pins in it. The should be able to operate the blue ring. Can make a photo of the correct location tonight if you need it. |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1910 ![]() ![]() |
Two things I'd add:
1) in your second pic, on the blue plastic ring around the steering column, you can make out an arrow moulded into the plastic. It's at the 12 o'clock position in your pic. It needs to be at the 9pm position - pointing towards the indicator stalk - when you fit/refit the wheel. 2) so, as tookaphotoof says, you need pins in your steering boss at (as it's fitted) the 12 o'clock and six o'clock poistions. I was having issues with this when I fitted an optimill boss. Don't really know why. It's got 'rolled' pins, so I just bent them a little to help them engage in the cancelling ring, but I'm not 100% sure it was needed. Anyway - my thought at the time was simply to tap a thread into the holes in the boss; cut the head of a long-ish bolt, and thread that into the boss. If you can't retrofit proper LR pins to that wheel, then maybe tapping a thread in would be a work-around?? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Roll pins are the things you're after.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
I believe that this is what you're missing.
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
Yes the blue plastic thing at 9 oclock I got that tip off Mike
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
As above you have a 2015MY wheel and a pre 2015MY indicator stalk setup. You need to add cancelling pins, the NRC7636 part won't fit the 2015MY wheel directly.
sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145 ![]() ![]() ![]() |
That would be great when you get chance, no rush at all, thank you |
Dorset3Landie Member Since: 06 Oct 2024 Location: Dorset Posts: 2 ![]() ![]() ![]() |
Thanks donmacn re the 9pm position thing. I'd have been ages figuring it out, Cheers.
