Home > Maintenance & Modifications > Self cancelling indicators don't work
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
My indicators don't self cancel so I took the steering wheel apart to try and fix the issue. Does anybody know what I need to get to fix the problem?...
This is the back of the steering wheel...
And this is where it mounts to the car...
Thanks for your help
Post #772100 8th May 2019 1:18pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
You're missing the pins. Guess your steering wheel is from one of the last Defenders.
edit: no need for a new steering wheel. You could drill to small holes in the rear and smash some hollow pins in it.
The should be able to operate the blue ring. Can make a photo of the correct location tonight if you need it.
Post #772104 8th May 2019 1:54pm
donmacn
Two things I'd add:
1) in your second pic, on the blue plastic ring around the steering column, you can make out an arrow moulded into the plastic. It's at the 12 o'clock position in your pic. It needs to be at the 9pm position - pointing towards the indicator stalk - when you fit/refit the wheel.
2) so, as tookaphotoof says, you need pins in your steering boss at (as it's fitted) the 12 o'clock and six o'clock poistions.
I was having issues with this when I fitted an optimill boss. Don't really know why. It's got 'rolled' pins, so I just bent them a little to help them engage in the cancelling ring, but I'm not 100% sure it was needed.
Anyway - my thought at the time was simply to tap a thread into the holes in the boss; cut the head of a long-ish bolt, and thread that into the boss.
If you can't retrofit proper LR pins to that wheel, then maybe tapping a thread in would be a work-around?? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #772107 8th May 2019 2:09pm
williamthedog
Roll pins are the things you're after. Thumbs Up
Post #772120 8th May 2019 3:40pm
I believe that this is what you're missing.
Post #772150 8th May 2019 5:49pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
Yes the blue plastic thing at 9 oclock I got that tip off Mike
Post #772158 8th May 2019 6:30pm
Martin
Site Admin
As above you have a 2015MY wheel and a pre 2015MY indicator stalk setup. You need to add cancelling pins, the NRC7636 part won't fit the 2015MY wheel directly.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #772161 8th May 2019 6:41pm
sgreenham
That would be great when you get chance, no rush at all, thank you
Post #772218 9th May 2019 7:21am
Dorset3Landie
United Kingdom 2001 Defender 90 Td5 HT Coniston Green
Thanks donmacn re the 9pm position thing. I'd have been ages figuring it out, Cheers.
Post #1070894 5th Jul 2025 11:49am
