Home > Td5 > Noticeable noise coming when driving above 60 km/h |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
Click image to enlarge Click image to enlarge Click image to enlarge I've recently had a belt snap seems like it was due to pulley bearing failure. After I had the car repaired. I've also noticed what may be front right side hub.. It sounds like something is not rolling right. I opened up the front diff to check the oil and it looks like the grease has leaked in from the Front hub. It's smells like grease and is the same color. My steering also feels a bit delayed. any suggestions? I will be rebuilding the HUB, the swivel and replacing the shocks. I do not like the mechanics around here so I will be attempting the work myself. |
7th May 2019 3:49am |
noise sound like wheel beaning failing may sawtoothing i.e. tyres
7th May 2019 8:20am |
