Noticeable noise coming when driving above 60 km/h
I've recently had a belt snap seems like it was due to pulley bearing failure. After I had the car repaired. I've also noticed what may be front right side hub.. It sounds like something is not rolling right. I opened up the front diff to check the oil and it looks like the grease has leaked in from the Front hub. It's smells like grease and is the same color.
My steering also feels a bit delayed.
any suggestions? I will be rebuilding the HUB, the swivel and replacing the shocks. I do not like the mechanics around here so I will be attempting the work myself.
7th May 2019 2:49am
gazman
With tyres that big have you jacked it up and checked the wheel bearing??2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
7th May 2019 4:39am
dorsetsmith
noise sound like wheel beaning failing may sawtoothing i.e. tyres
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
