![]() | Home > Puma (Tdci) > Puma Engine wiring Harness |
kenhills Member Since: 06 Jan 2013 Location: Scotland Posts: 4 ![]() ![]() ![]() |
On a recent trip to Morocco the engine went into limp home mode with a Turbor sensor A wiring circuit fault
![]() This is a real weak point as the wiring goes throughs a sharp angle into the plug and repeated shaking appears to be damaging all of the wires. I managed to get a bodge done but am now looking for a new wiring harness for the engine. Does anyone know the part no for this harness? Ken |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Yes this is a known problem and there is a service bulletin for. You don’t need the complete loom there is a repair kit for this problem. If nobody beats me to it
![]() And if you wondered, Yes i had the same problem ![]() |
The service bulletin is: LTB00254/2010
And the replacement/fix: Causal Part: LR007352 LTB00254 - Turbo Modulator Service Link Kit, service fix lead (LR020663) a defender from 1984 pretending to be a puma with a touch of Range Rover |
Thats really helpful - thanks V Much
You're very welcome. Good luck with the repair. a defender from 1984 pretending to be a puma with a touch of Range Rover
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
8-( I'll check that.
From at least MY2012 there is an unfused cable from the alternator to the starter motor (from there it continues to the battery via 500A fuse). Is that one prone to chafing? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17838 ![]() ![]() ![]() |
Probably, it does no harm to check.
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 775 ![]() ![]() ![]() |
One of the recommended work stated by my mechanic after my Defender got dunked is to replace all the wiring harnesses as the dunking will have caused corrosion and will eventually give me gremlins.
Anyone know where I can get new ones that won't require me to sell organs or maybe someone who can make better harnesses from scratch? |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Defender.net is a huge source of information!
Probably I have the same fault now. Near randomly lack of turbo, rough driving and high fuel consumption. Engine Harness looks quite worn in the area were the cables passes the engine, so probably is the fault. So I will check during weekend to see if that solves the issue. Cheers and thanks! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
