Home > Puma (Tdci) > Puma Engine wiring Harness
kenhills
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
On a recent trip to Morocco the engine went into limp home mode with a Turbor sensor A wiring circuit fault Big Cry . This turned out to be a broken wire on the plug attaching the engine wiring harness to the Turbo control box.
This is a real weak point as the wiring goes throughs a sharp angle into the plug and repeated shaking appears to be damaging all of the wires. I managed to get a bodge done but am now looking for a new wiring harness for the engine.
Does anyone know the part no for this harness? Ken
Post #770642 29th Apr 2019 10:19am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Yes this is a known problem and there is a service bulletin for. You don’t need the complete loom there is a repair kit for this problem. If nobody beats me to it Rolling with laughter i’ll try to find the bulletin.
And if you wondered, Yes i had the same problem Laughing a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770643 29th Apr 2019 10:25am
Tdi4
The service bulletin is: LTB00254/2010
And the replacement/fix: Causal Part: LR007352
LTB00254 - Turbo Modulator Service Link Kit, service fix lead (LR020663) a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770645 29th Apr 2019 10:36am
kenhills
Thats really helpful - thanks V Much
Bow down Ken
Post #770648 29th Apr 2019 10:41am
Tdi4
You're very welcome. Good luck with the repair. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #770651 29th Apr 2019 11:44am
Be aware also that generally the engine harness is not very satisfactory for vehicle used in anything remotely resembling arduous conditions. The harness is extremely prone to chafing at every point where it is in contact with the engine. The designer clearly though that the only protection the harness needs is convoluted sleeving, which is wholly inadequate
I suffered turbo problems which turned out to be caused by the wires to the actuator becoming completely severed due to chafing at the point where the harness passes the top front of the engine. Although an easy repair, it was sobering to see that the main feed from the alternator to the battery was similarly chafed, to the point where bare conductors were visible. I have absolutely no idea how it is that this didn't cause a major fire (I think that I spotted it just in time). This connection between the battery and the alternator is not fused at either end, so would cause a dead short to ground of both the battery and the alternator output if the engine is running. It doesn't really bear thinking about and can have only one result.
If my vehicle is representative of the quality of TDCi Defenders in general, it is wonder that spontaneous combustion isn't a widespread occurrence.
I strongly recommend that you check the harness throughout its length.
Post #770652 29th Apr 2019 11:56am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
8-( I'll check that.
From at least MY2012 there is an unfused cable from the alternator to the starter motor (from there it continues to the battery via 500A fuse). Is that one prone to chafing?
Post #770736 29th Apr 2019 7:09pm
Probably, it does no harm to check.
Post #770783 29th Apr 2019 10:14pm
HardCharger
One of the recommended work stated by my mechanic after my Defender got dunked is to replace all the wiring harnesses as the dunking will have caused corrosion and will eventually give me gremlins.
Anyone know where I can get new ones that won't require me to sell organs or maybe someone who can make better harnesses from scratch?
Post #770793 30th Apr 2019 2:00am
Eduardo
Defender.net is a huge source of information!
Probably I have the same fault now.
Near randomly lack of turbo, rough driving and high fuel consumption.
Engine Harness looks quite worn in the area were the cables passes the engine, so probably is the fault.
So I will check during weekend to see if that solves the issue.
Cheers and thanks! Eduardo
Post #778280 20th Jun 2019 5:23pm
