Home > Maintenance & Modifications > Headline trees
Procta
Headline trees
I have a problem with the Headline trees not locking into the holes, two just don't want to play ball at all, its as though the holes are too big for the trees to lock into, any advice or tips you lads can give? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #770106 25th Apr 2019 9:03pm
landy andy
Buy new. Only cheap on eBay.
Post #770112 25th Apr 2019 9:12pm
hank
Although not fitted to the roof lining panel holes from the factory, you could use the inserts found under the floor mats that the fir trees locate into.
These effectively reduce the panel hole diameter slightly giving the fir trees something to grip on to. May solve your problem
Item 4 in the below
Alternatively get some fatter fir trees!
https://www.lrworkshop.com/diagrams/land-r...loor_45033
 > 110 XS Double Cab
Post #770120 25th Apr 2019 9:36pm
ChrisDefender
Hi Procta
I put a bit of heat shrink on a couple in mine to thicken them up a little but still keep the grooves, its never moved since! Very Happy
Post #770269 26th Apr 2019 7:36pm
