![]() | Home > Maintenance & Modifications > Headline trees |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Buy new. Only cheap on eBay.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Although not fitted to the roof lining panel holes from the factory, you could use the inserts found under the floor mats that the fir trees locate into.
These effectively reduce the panel hole diameter slightly giving the fir trees something to grip on to. May solve your problem Item 4 in the below Alternatively get some fatter fir trees! https://www.lrworkshop.com/diagrams/land-r...loor_45033 ![]() Click image to enlarge > 110 XS Double Cab |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 469 ![]() ![]() |
Hi Procta
I put a bit of heat shrink on a couple in mine to thicken them up a little but still keep the grooves, its never moved since! ![]() |
