![]() | Home > Technical > TD5 - drivers electric window and door card - help needed |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Will put money on it being broken wires in the rubber convoluted tube which runs from the a-pillar to the door.
The plastic sheeting (water shedder) is original. Steve 02' 110 TD5 Double Cab Rebuild Thread |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142
Have a look here the photos and instructions may help you in taking out the metal frame
http://issuu.com/mobilecentre/docs/lrm_electric_windows For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
| Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 197
Thanks for the help.
Quick power test and no reading. Pulled the blue wire and hey presto! Click image to enlarge Just got to replace blue and red wires now. Defender Td5 XS90 |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
Just a tip. As a precaution also change the other thick wire.
And do not Just connect the 2 pieces. Insertie a new piece of wire through the whole rubber tube. a defender from 1984 pretending to be a puma with a touch of Range Rover |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Paul Mc can sort you Electric Windows - Front Doors Connectors
https://www.ebay.co.uk/itm/DEFENDER-TD5-PU...XQTgZQ9~Ko |
Changed both wires and put back together except door card as waiting for a couple of fixings.
thanks for the help, Andy Defender Td5 XS90 |
| All times are GMT |
