Home > Maintenance & Modifications > Puma 110 fuel tank guard
Arthur Mak
Hong Kong 2012 Defender 110 Puma 2.2 SW Orkney Grey
I would like to add a fuel tank guard for my 110 as I was a bit naughty for climbing.
After google, I found that the anti roll bar have to be removed when installing a fuel tank guard. Is there ways to have both the anti roll bar and fuel tank guard at the same time?
Post #767767 9th Apr 2019 1:39am
I did on mine (Td5, but similar to puma).
I just welded up a couple of box section spacers to lower the A/R bar down a bit so it cleared the guard.
Post #767777 9th Apr 2019 6:59am
landy andy
You can use tow bar spacers to space off the towball from memory.
Post #767782 9th Apr 2019 8:12am
landy andy
Post #767783 9th Apr 2019 8:13am
leeds
IIRC Safari Equip do some anti roll bar spacers for their larger fuel tanks. These are square tubes with a flange welded on at either end. Think it lowers anti roll bar mount by about 3” which is probably excessive for OP use.
Brendan
Post #767785 9th Apr 2019 8:24am
leeds
Double post, sorry
Brendan
Post #767786 9th Apr 2019 8:24am
It is quite easy to lower the ARB mounts with rudimentary spacers.
Post #767806 9th Apr 2019 11:09am
Arthur Mak
Thank you sirs.
I got it.
Post #767831 9th Apr 2019 1:59pm
