![]() | Home > Maintenance & Modifications > Puma 110 fuel tank guard |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
I did on mine (Td5, but similar to puma).
I just welded up a couple of box section spacers to lower the A/R bar down a bit so it cleared the guard. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
You can use tow bar spacers to space off the towball from memory.
IIRC Safari Equip do some anti roll bar spacers for their larger fuel tanks. These are square tubes with a flange welded on at either end. Think it lowers anti roll bar mount by about 3” which is probably excessive for OP use.
Brendan |
Double post, sorry
Brendan |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17859 ![]() ![]() ![]() |
It is quite easy to lower the ARB mounts with rudimentary spacers.
Arthur Mak Member Since: 08 Sep 2016 Location: Hong Kong Posts: 11 ![]() ![]() ![]() |
Thank you sirs.
I got it. |
