Home > Technical > Vibration steering wheel
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I sometimes have a vibration through my steering wheel. It can happen around 55 / 65 mph.
Strange thing is, I don’t have it always and it. Keeping exactly the same speed the vibration ca occur or disappear.
Anyone know what I should look for first?
Post #767589 8th Apr 2019 10:43am
Tyre balance. I used to find the same thing and in the end concluded that it was caused by imbalance in the front tyres which would come into phase across the vehicle from time to time due to steering geometry. It was completely solved in my case by switching to dynamic balancing beads instead of fixed weights.
There are, of course, other possible causes too, but - especially if you run MTs - this would be my first suspicion.
Post #767609 8th Apr 2019 12:20pm
tookaphotoof
Thanks. BFG KO2 on mine, but I'll see if I can order some balancing beads to try first.
Post #767653 8th Apr 2019 5:30pm
JOW240725
I had this and it was just the wheel balance. Good luck. James
Instagram @suffolk_rovers
Post #767688 8th Apr 2019 7:20pm
tookaphotoof
Thumbs Up
Post #767787 9th Apr 2019 7:33am
ARC99
I had this sort problem on a Discovery that was driving me mad. I had the wheel balanced about 3 times at different places, both front wheels stripped and new bearings still couldn't sort it. The Indy I was using had to take on a mechanic over the summer to cover for holidays this turned out to be a retired mechanic with years of experience of Land Rovers, he took it out for a drive and when he came back pronounced that it was the steering damper that was starting to fail, so it was changed and that fixed the problem. Don't make old people mad.
Richard
Post #767794 9th Apr 2019 8:32am
tookaphotoof
Richard, thanks.
I figured I might as well change the damper for a fresh unit first so ordered one from OME. Had a laugh when I took the old one out. It was past its way out! Laughing
I’ll have my wheels checked anyways but boy, does it make a difference, already! Bow down
Post #768166 11th Apr 2019 5:27pm
X4SKP
Interesting read tookaphotoof… did you... Question SKIP
Post #768167 11th Apr 2019 5:45pm
tookaphotoof
Laughing
Something like these crappy phone pics?
Post #768251 12th Apr 2019 8:33am
ARC99
tookaphotoof wrote:
Richard, thanks.
Thumbs Up
Its one of the things about this forum, someone more than likely will have had a similar problem and they are not afraid to share the experience and the fix. Don't make old people mad.
Richard
Post #768253 12th Apr 2019 8:42am
DOOFER
Worth checking the panhard rod bushes too. Cheap as chips and easy to change. DON'T PANIC
Post #768255 12th Apr 2019 9:13am
Bumpy
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Rimini Red
I've been having the same problem. Apparently, when fitting bigger tyres and wheels, the swivel pin preload should be adjusted. Start by removing the smallest shim each side to see if this alleviates the problem. If the steering wheel doesn't self-centre when moving then too many shims have been taken out.
My next stop is DynaBeads if this doesn't work.
Post #768273 12th Apr 2019 12:51pm
X4SKP
Post #768279 12th Apr 2019 1:24pm
tookaphotoof
Will do! Thanks.
Post #768338 12th Apr 2019 8:19pm
Marzano
United States
DOOFER wrote:
Worth checking if these excellent payday loans are for you and the panhard rod bushes too. Cheap as chips and easy to change.
Is the quality still somewhat there? Cheap things always make me a bit nervous.
Post #769574 22nd Apr 2019 10:30am
