Home > Puma (Tdci) > No Power, Engine Lamp Illuminated, 2 DTCs : P2263 + P0101 |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 315 |
Yesterday my 2.2 puma lost power & the engine lamp came on.
Two fault codes recorded: P2263 & P0101 Anyone had this combination? Any ideas? |
7th Apr 2019 3:43pm |
Thanks, fingers crossed hope that's all it turns out to be...
7th Apr 2019 4:54pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
P0101-16 Mass or Volume Air Flow Sensor “A” Circuit Range/Performance -Circuit voltage below threshold
Possible Causes: Intake system blocked/leaking Mass air flow and temperature sensor circuit short circuit to ground, open circuit, high resistance Mass air flow and temperature sensor internal failure Action: Check the intake system for blockages/leaks. Refer to the electrical circuit diagrams and check the mass air flow and temperature sensor circuit for short circuit to ground, open circuit, high resistance Install a new mass air flow and temperature sensor as necessary P2263-21 Turbocharger/Supercharger Boost System Performance- Signal amplitude < minimum Possible Causes: Intake system blocked/leaking Manifold absolute pressure and temperature sensor fault Variable geometry turbine vane actuator fault Turbocharger failure Action: Check the intake system for blockages/leaks, check for manifold absolute pressure and temperature sensor related DTCs and perform the relevant corrective actions Check the variable geometry turbine vane actuator linkage. Check the turbocharger bearing and oil seal. Install a new turbocharger as necessary. Cut and pasted the above from B.A.S. website. Yes I've had them together - split intercooler hose and dead MAP sensor. Hope that helps |
7th Apr 2019 8:50pm |
Thanks shropshiredefender
7th Apr 2019 10:23pm |
New intercooler fitted & all sorted !
Well happy ! |
11th Apr 2019 10:31pm |
Jas Ardis Member Since: 28 Jun 2018 Location: Salisbury Posts: 56 |
Had a limp home evening yesterday in my ‘12 reg 2.2 Puma - very frustrating. Looked under the bonnet today and there appears to be a 1cm slot in one of the hoses ... see pic. Would this be the cause? No other codes, just the P2263.
Tempted to replace all the hoses ... recommendations? Much appreciated! Jas |
26th Jun 2019 8:52pm |
Click image to enlarge Here’s the pic ... I’ve indicated the damage with a white marker. (Vehicle pointing to the left!) |
26th Jun 2019 8:55pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Jas
I replaced all my hoses on Monday this week with ones from BAS. High quality items but in fairness anything of quality does cost that bit more. The service from Pete was amazing, I’m very impressed with them. I have kept all the old hoses that I removed, they were fine but because I did the intercooler I upgraded the hoses, if you would like the old hoses your very welcome to them for the cost of the postage 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
26th Jun 2019 9:18pm |
That’s really kind of you - though to be honest I think you’re right to replace them all with aftermarket hoses, and I’ll very likely do the same; BAS provided silicone hoses, I assume? From all I’ve read the factory tubes are really not up to the job.
Thanks for the heads up! |
26th Jun 2019 10:04pm |
Yes I used the BAS hoses fitted to an Alive hiflow intercooler with an Alive stage 1 remap, tomorrow it will be an Alive stage 2 remap I’m like a kid on Christmas Eve here tonight 2015 HT XS 90
26th Jun 2019 10:18pm |
Coooool! Pictures tomorrow of the engine and shiny bits?
26th Jun 2019 10:40pm |
