Home > Puma (Tdci) > No Power, Engine Lamp Illuminated, 2 DTCs : P2263 + P0101
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Yesterday my 2.2 puma lost power & the engine lamp came on. Sad
Two fault codes recorded: P2263 & P0101
Anyone had this combination? Any ideas?
Post #767421 7th Apr 2019 3:43pm
Siwynne
Intercooler hoses probably causing them.
Same codes three different times in the past.
Two hoses and and intercooler.
Post #767424 7th Apr 2019 3:52pm
JPE
Thanks, fingers crossed hope that's all it turns out to be...
Post #767432 7th Apr 2019 4:54pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
P0101-16 Mass or Volume Air Flow Sensor “A” Circuit Range/Performance -Circuit voltage below threshold
Possible Causes: Intake system blocked/leaking Mass air flow and temperature sensor circuit short circuit to ground, open circuit, high resistance Mass air flow and temperature sensor internal failure
Action: Check the intake system for blockages/leaks. Refer to the electrical circuit diagrams and check the mass air flow and temperature sensor circuit for short circuit to ground, open circuit, high resistance Install a new mass air flow and temperature sensor as necessary
P2263-21 Turbocharger/Supercharger Boost System Performance- Signal amplitude < minimum
Possible Causes: Intake system blocked/leaking Manifold absolute pressure and temperature sensor fault Variable geometry turbine vane actuator fault Turbocharger failure
Action: Check the intake system for blockages/leaks, check for manifold absolute pressure and temperature sensor related DTCs and perform the relevant corrective actions Check the variable geometry turbine vane actuator linkage. Check the turbocharger bearing and oil seal. Install a new turbocharger as necessary.
Cut and pasted the above from B.A.S. website.
Yes I've had them together - split intercooler hose and dead MAP sensor.
Hope that helps Thumbs Up Thumbs Up
Post #767487 7th Apr 2019 8:50pm
JPE
Thanks shropshiredefender
Post #767518 7th Apr 2019 10:23pm
JPE
New intercooler fitted & all sorted ! Thumbs Up
Well happy ! Very Happy
Post #768220 11th Apr 2019 10:31pm
Jas Ardis
United Kingdom 2012 Defender 110 Puma 2.2 USW Auto Stornoway Grey
Would this cause a P2263?
Had a limp home evening yesterday in my ‘12 reg 2.2 Puma - very frustrating. Looked under the bonnet today and there appears to be a 1cm slot in one of the hoses ... see pic. Would this be the cause? No other codes, just the P2263.
Tempted to replace all the hoses ... recommendations?
Much appreciated!
Jas
Post #779156 26th Jun 2019 8:52pm
Jas Ardis
Pic
Here’s the pic ... I’ve indicated the damage with a white marker.
(Vehicle pointing to the left!)
Post #779157 26th Jun 2019 8:55pm
Sulisuli
Jas
I replaced all my hoses on Monday this week with ones from BAS. High quality items but in fairness anything of quality does cost that bit more. The service from Pete was amazing, I’m very impressed with them.
I have kept all the old hoses that I removed, they were fine but because I did the intercooler I upgraded the hoses, if you would like the old hoses your very welcome to them for the cost of the postage Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #779159 26th Jun 2019 9:18pm
Jas Ardis
That’s really kind of you - though to be honest I think you’re right to replace them all with aftermarket hoses, and I’ll very likely do the same; BAS provided silicone hoses, I assume? From all I’ve read the factory tubes are really not up to the job.
Thanks for the heads up! Thumbs Up
Post #779165 26th Jun 2019 10:04pm
Sulisuli
Yes I used the BAS hoses fitted to an Alive hiflow intercooler with an Alive stage 1 remap, tomorrow it will be an Alive stage 2 remap Thumbs Up I’m like a kid on Christmas Eve here tonight Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #779168 26th Jun 2019 10:18pm
Jas Ardis
Coooool! Pictures tomorrow of the engine and shiny bits?
Post #779172 26th Jun 2019 10:40pm
