Home > Technical > Help relearn remote and immobiliser? |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1867 |
Update
if i turn the ignition to the second position, dash lights up as normal red light still on and after a few seconds the horn beeps twice? still no remote or engine start 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
24th Mar 2019 7:51pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
what defender is this? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
25th Mar 2019 8:18pm |
madfrankie Member Since: 10 Oct 2016 Location: Hertfordshire Posts: 356 |
have you tried disconnecting the battery for 10 mins and then reconnecting.
sometimes reboots the immobiliser "Of Course, Of course, I ain't asking . I'm telling!!" |
25th Mar 2019 8:30pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
Alarm unit shouldn't forget it's settings or plippers.... unplugging it would be the same as having a (dead) flat battery.
As above, maybe it needs a longer "power down" to reset itself. |
25th Mar 2019 9:07pm |
Thanks guys, been away all week and just done as you said, disconnected the battery for 10 mins, pressed unlock 7 times and it’s all working again! Thank you very much!! 2016 Range Rover Autobiography 4.4 TDV8
29th Mar 2019 6:39pm |
Glad you it fixed unit shouldn't forget it's settings or plippers.... by unplugging i have them out and off for replare week plugg them back in with no problem
29th Mar 2019 8:27pm |
