Home > Technical > Help relearn remote and immobiliser?
bear100
Help!
While trying to locate the orange cable for the remote wire extension mod my son in his wisdom decided to remove the grey and green plugs on the alarm module under the drivers dash, now no remote and the engine won’t start Big Cry
The red led on the dash just stays on, is there a simple soution to this? Rolling Eyes 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #765168 24th Mar 2019 4:11pm
bear100
Update
if i turn the ignition to the second position, dash lights up as normal red light still on and after a few seconds the horn beeps twice? still no remote or engine start Big Cry Big Cry Big Cry 2023 Defender L663 V8
Post #765208 24th Mar 2019 7:51pm
Procta
what defender is this? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #765359 25th Mar 2019 8:18pm
madfrankie
England 2007 Defender 90 Puma 2.4 SW Stornoway Grey
have you tried disconnecting the battery for 10 mins and then reconnecting.
sometimes reboots the immobiliser "Of Course, Of course, I ain't asking . I'm telling!!"
Post #765362 25th Mar 2019 8:30pm
Alarm unit shouldn't forget it's settings or plippers.... unplugging it would be the same as having a (dead) flat battery.
As above, maybe it needs a longer "power down" to reset itself.
Post #765367 25th Mar 2019 9:07pm
bear100
Thanks guys, been away all week and just done as you said, disconnected the battery for 10 mins, pressed unlock 7 times and it’s all working again! Thank you very much!! Thumbs Up 2023 Defender L663 V8
Post #765983 29th Mar 2019 6:39pm
dorsetsmith
Glad you it fixed Thumbs Up unit shouldn't forget it's settings or plippers.... by unplugging i have them out and off for replare week plugg them back in with no problem
Post #765995 29th Mar 2019 8:27pm
