![]() | Home > Maintenance & Modifications > Bbus help required |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
Largely driven by panic when I saw a chap under m defender in a car park, he said he was retrieving a letter he dropped, I purchased a Bbus wiring loom extension kit from Deerfold on here last week.
It did take a while for the penny to drop and to realise that I did not have clue what to do with it. My car is a 2015 90 Puma TdCi. Any assistance in fitting it would be greatly appreciated. Many thanks A somewhat confused, (not difficult these days) ![]() Swine ps. Small was not much help either ![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
Blimey, id of wanted to see the letter, and id of taken a pic of him!!, maybe of followed him to his vehical and got the details lol!!!! Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
That is brilliant and so appreciated. My alarm works as I set it off by mistake the other day and Small almost had a heart attack. I will set to with this tomorrow. Hope that it is another layer of security covered.
Regards Swine 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343 ![]() ![]() ![]() |
Hi Swine, it is a while since I moved mine and I no longer have the Defender to check, but before you remove the headlamp unit, just check to see if you can reach the BBUS siren from inside the bonnet area. I can't remember if there is access to reach up into the front inner wing area, or if the radiator and/or other bodywork panels won't allow you to get to the BBUS.
I do remember removing my headlight and reaching up to locate/undo the BBUS, but can't remember if that was actually the way I extracted it !!!! |
Ok. LOHR,
Thanks for the advice ,I will check and be careful ![]() Regards 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 ![]() |
Not something you would like to see on returning to your Defender.
Possibly a plausible excuse, though I would have a route around underneath for any sign of anything attached, ie a tracker of sorts. This type of incident is getting more common with high end bicycles where a small tracker is attached in a public place, though the bike is not taken until later at a time and location much less conspicuous. Again I would hope for an innocent excuse.... |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
As an extra security step i would extend the feed from the bonnet alarm trigger to the headlight panel (with a switch)and when they unscrew the panel the alarm will go off ......you might scare them off before they do anymore damage. |
Thanks for that tip
