Home > Td5 > Access to front windscreen washer pipe |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 623 |
Usual small diameter pipe. 4.7mm id.
You might be able to access via the ash tray hole but otherwise it is the dash top that needs to come off. 1995 Defender 110 CSW 1971 SIIA Lightweight |
18th Mar 2019 3:28pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5725 |
Cheers. I did have a look into the void via the ashtray hole but wasn't looking favourable. Top dash off time 1999 Defender TD5 110
18th Mar 2019 3:46pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4348 |
if you need to replace the washer nozzle then you will need to remove the dash; From memory... Instrument binnacle off - 4 screws Windscreen vent trim off - 4 screws Passenger grab handle off - Small screw bottom of handle and screw under LR logo A pillar trim off - 4 screws Dash top big screws - 3 screws on top and 3/4 small screws under dah top lip Dash slides forward before lifting off. Think that's it... If it is only the pipe that's leaking you can do it via the ash tray if you have small fingers... |
18th Mar 2019 7:02pm |
hi. Just the pipe I hope. I have moved my washjet to the middle, so not able to go via tray... 1999 Defender TD5 110
18th Mar 2019 7:41pm |
Ha if it makes you feel better i will also removing the dash in order to fit the wiring for the new heated screen...
Love the challenge... |
18th Mar 2019 8:08pm |
Cheers, makes me feel better! 1999 Defender TD5 110
18th Mar 2019 8:13pm |
