Home > Td5 > Access to front windscreen washer pipe
excossack
The washer pipe is leaking... Sad
To get access to it, do I just need to remove the top dash section? and any ideas on the size of washer pipe required? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #764163 18th Mar 2019 4:16pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Usual small diameter pipe. 4.7mm id.
You might be able to access via the ash tray hole but otherwise it is the dash top that needs to come off. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #764165 18th Mar 2019 4:28pm
excossack
Cheers. I did have a look into the void via the ashtray hole but wasn't looking favourable. Top dash off time 1999 Defender TD5 110
Regards
John M0VAZ
Post #764168 18th Mar 2019 4:46pm
geobloke
Re: Access to front windscreen washer pipe
if you need to replace the washer nozzle then you will need to remove the dash;
From memory...
Instrument binnacle off - 4 screws
Windscreen vent trim off - 4 screws
Passenger grab handle off - Small screw bottom of handle and screw under LR logo
A pillar trim off - 4 screws
Dash top big screws - 3 screws on top and 3/4 small screws under dah top lip
Dash slides forward before lifting off. Think that's it...
If it is only the pipe that's leaking you can do it via the ash tray if you have small fingers...
Post #764191 18th Mar 2019 8:02pm
excossack
hi. Just the pipe I hope. I have moved my washjet to the middle, so not able to go via tray... Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #764197 18th Mar 2019 8:41pm
geobloke
Ha if it makes you feel better i will also removing the dash in order to fit the wiring for the new heated screen...
Love the challenge... Thumbs Up Thumbs Up
Post #764203 18th Mar 2019 9:08pm
excossack
Cheers, makes me feel better! 1999 Defender TD5 110
Regards
John M0VAZ
Post #764204 18th Mar 2019 9:13pm
