Home > Technical > Going from a Tdi to a Td5/Puma ignition switch?
donmacn
As per my other post tonight (about 'shims' behind the felt glass channels) i'm rebuilding onto new doors.
One of the implications is newer door handles and larger lock barrels. There's a kit I can get with a new ignition switch and three new barrels. This means I could use the one key for doors and ignition - but I wonder if the later ignition switch is a straightforward plug in, or is the wiring different?
I'vd no worries doing some basic wiring work, but if it's more complex than that, it might be too much of a hassle.
My car is a 94 300Tdi, the larger barrels and switch are for a Puma/TD5
Ta Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #764089 17th Mar 2019 10:10pm
Martin
Site Admin
Same switch has been fitted from 200 Tdi onwards Smile
Make a note of the locations you remove the wires from the old switch as they are separate tabs not a multi-pin plug.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764105 18th Mar 2019 8:41am
donmacn
Thanks muchly, Martin - makes life a lot easier! Donald
in the past..
Post #764106 18th Mar 2019 8:45am
