![]() | Home > Technical > Going from a Tdi to a Td5/Puma ignition switch? |
| donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1917
As per my other post tonight (about 'shims' behind the felt glass channels) i'm rebuilding onto new doors.
One of the implications is newer door handles and larger lock barrels. There's a kit I can get with a new ignition switch and three new barrels. This means I could use the one key for doors and ignition - but I wonder if the later ignition switch is a straightforward plug in, or is the wiring different? I'vd no worries doing some basic wiring work, but if it's more complex than that, it might be too much of a hassle. My car is a 94 300Tdi, the larger barrels and switch are for a Puma/TD5 Ta Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6735
Same switch has been fitted from 200 Tdi onwards
Make a note of the locations you remove the wires from the old switch as they are separate tabs not a multi-pin plug. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Thanks muchly, Martin - makes life a lot easier! Donald
| All times are GMT |
