Home > Puma (Tdci) > Each time I push the clutch I hear a "gneck" noise
Fiebre
Spain 2008 Defender 90 Puma 2.4 SW Java Black
Hello,
I need your help.
I started to hear a "gneck" noise each time I push my clutch pedal.
I don't know if the spring on the pedal need some grease, and what should be the best one to use it.
I don't know how to solve it.
Thanks for your feedback
Post #763780 16th Mar 2019 1:39pm
dotom
Germany 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi Fiebre,
I have the same sound from the spring from time to time. I use white grease from a spray can which sticks very good and the squeaking sound is gone. But comes back after a few months.
Press the clutch when you use the grease, that it also comes between the windings of the spring.
Hope that helps
Tom
Post #763812 16th Mar 2019 4:57pm
kmac
Lots of threads on here on this - best to access the clutch mech from the engine bay and grease there. That's what i did - problem fixed
See first pic in this thread
https://www.defender2.net/forum/topic45191...eak+clutch
Post #763956 17th Mar 2019 11:57am
Fiebre
Thanks a lot all.
I will try.
Post #763968 17th Mar 2019 1:01pm
