![]() | Home > Puma (Tdci) > Each time I push the clutch I hear a "gneck" noise |
| dotom Member Since: 04 Feb 2012 Location: Dortmund Posts: 95
Hi Fiebre,
I have the same sound from the spring from time to time. I use white grease from a spray can which sticks very good and the squeaking sound is gone. But comes back after a few months. Press the clutch when you use the grease, that it also comes between the windings of the spring. Hope that helps Tom |
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1323
Lots of threads on here on this - best to access the clutch mech from the engine bay and grease there. That's what i did - problem fixed
See first pic in this thread https://www.defender2.net/forum/topic45191...eak+clutch |
| Fiebre Member Since: 24 Jun 2015 Location: Sabadell Posts: 25
Thanks a lot all.
I will try. |
