![]() | Home > Technical > Td5 new steering pump , pipe don’t fit |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6038 ![]() ![]() ![]() |
Maybe your local hydraulic place could make you a flexi pipe up with the correct ends? 1999 Defender TD5 110
As above may be your best bet. Was in pretty much the same position a couple of years ago when I snapped the same part on the pump body. I couldn't find the right part that screws into the pump for love nor money and ended up buying another secondhand pump from a breaker.
gtmotorsport Member Since: 29 Jun 2016 Location: Cornwall Posts: 97 ![]() ![]() ![]() |
I maybe completely wrong, but from the photo the pump looks to have a threaded adapter already inserted. Is it possible this needs to be removed for your pipe to be installed?
![]() Click image to enlarge have read below https://www.defender2.net/forum/topic15873.html?view=previous |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6720 ![]() ![]() ![]() |
Also https://www.defender2.net/forum/topic15746.html?highlight=pas
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6217 ![]() ![]() ![]() |
Spooky that it's me that's the starter of both those threads!
I /may/ have an old pump in the garage.... I'll take a look when I get in. If it's got the correct union on it you're more than welcome to it Razz... pass it on and all that. |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
Hello everyone , many thanks for all your fantastic replies
![]() Ady |
Just had a rummage around the garage....
It was the water pump thing I had off the front of a Td5 alterntor. sorry. not the PAS pump I thought I had. |
No worries Jim , thanks for looking , I have purchased another pump , so all will be sorted soon , thanks everyone
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18018 ![]() ![]() ![]() |
I think that'll actually be a vacuum pump then, not a water pump! |
