Home > Td5 > TD5 Fails to Start. Frothy Fuel from High Pressure Line
stevejohns72
I am Steven Johns and I own a Defender TD5 2004 Model. My Defender doesnt start. I noticed that the fuel from the high pressure line to the engine is frothy. I have replaced the pump and it is still the same. Can anyone assist
Post #763424 14th Mar 2019 3:02pm
4RF RDS
Sounds like a possible air leak into the fuel system. Is your FPR leaking? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #763427 14th Mar 2019 3:53pm
stevejohns72
The FPR is new and it is not leaking. However prior to the incident I noticed that the fuel return to the pump was extremely hot to the extent that one would get burned if they touched the fuel filter. I replaced the injector washers and the O-rings.
Post #763430 14th Mar 2019 4:04pm
4RF RDS
Okay, have you plugged it in to a code reader? Are there any codes? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #763432 14th Mar 2019 4:11pm
stevejohns72
I do not see any faults on my code reader. I am using the Hawkeye Diagnostic tool from Bearmach. I will check again and revert
Post #763437 14th Mar 2019 4:18pm
dorsetsmith
Is fuel filter head OK
none return valve can cores problems with starting fuel running back
Technical Service bulletin Air bleed
http://gershon.ucoz.com/landrover/TD5/TOPI...oisy_F.pdf
Post #763441 14th Mar 2019 4:41pm
stevejohns72
I will need to check this one. I will swap it with another one and see the difference.
Post #763442 14th Mar 2019 4:43pm
4RF RDS
Yup next thing to check is that. The aluminum can become corroded and porous. That little valve thingy is also PITA when it gets blocked. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #763468 14th Mar 2019 6:32pm
lightning
The fuel return shouldn’t be red hot. That needs investigating as it could be dangerous.
Post #763707 15th Mar 2019 9:24pm
dorsetsmith
check fuel return cooler has coolant flowing throw the unit, is on the drivers side underneath the top engine cover
Post #763710 15th Mar 2019 9:28pm
dorsetsmith
As up date to post 98 to 2004 type fuel cooler have a themost on the coolant inlet to the unit can cores problems with coolant flow Exclamation
Post #764206 18th Mar 2019 9:44pm
stevejohns72
I have changed the fuel pump and the filter housing. Fuel seems to be flowing with pressure now, but the vehicle still doesnt start. I used the Hawkeye diagnostic tool and there is no error displayed. Could this be a crank sensor problem. What are the symptoms of a bad crank sensor?
I also noticed that the fuel return from the cooler to the tank returns with pressure. Is that normal?
Post #768157 11th Apr 2019 3:48pm
dorsetsmith
Can you see crank sensor rpm out put on Hawkeye diagnostic live date Question
Post #768181 11th Apr 2019 8:12pm
stevejohns72
Thanks guys
It has finally started. I needed to bleed it for a while by depressing the pedal 5 times. I will drive it a long distance and observe it.
Post #768195 11th Apr 2019 9:00pm
dorsetsmith
good to hear
Post #768211 11th Apr 2019 10:06pm
