![]() | Home > Td5 > TD5 Fails to Start. Frothy Fuel from High Pressure Line |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 978 ![]() ![]() ![]() |
Sounds like a possible air leak into the fuel system. Is your FPR leaking? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
stevejohns72 Member Since: 09 Sep 2013 Location: Monrovia, Liberia Posts: 16 ![]() |
The FPR is new and it is not leaking. However prior to the incident I noticed that the fuel return to the pump was extremely hot to the extent that one would get burned if they touched the fuel filter. I replaced the injector washers and the O-rings.
Okay, have you plugged it in to a code reader? Are there any codes? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
I do not see any faults on my code reader. I am using the Hawkeye Diagnostic tool from Bearmach. I will check again and revert
Is fuel filter head OK
![]() Click image to enlarge none return valve can cores problems with starting fuel running back ![]() Technical Service bulletin Air bleed http://gershon.ucoz.com/landrover/TD5/TOPI...oisy_F.pdf Last edited by dorsetsmith on 14th Mar 2019 4:59pm. Edited 2 times in total |
I will need to check this one. I will swap it with another one and see the difference.
Yup next thing to check is that. The aluminum can become corroded and porous. That little valve thingy is also PITA when it gets blocked. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3246 ![]() ![]() |
The fuel return shouldn’t be red hot. That needs investigating as it could be dangerous.
check fuel return cooler has coolant flowing throw the unit, is on the drivers side underneath the top engine cover
As up date to post 98 to 2004 type fuel cooler have a themost on the coolant inlet to the unit can cores problems with coolant flow
I have changed the fuel pump and the filter housing. Fuel seems to be flowing with pressure now, but the vehicle still doesnt start. I used the Hawkeye diagnostic tool and there is no error displayed. Could this be a crank sensor problem. What are the symptoms of a bad crank sensor?
I also noticed that the fuel return from the cooler to the tank returns with pressure. Is that normal? |
Can you see crank sensor rpm out put on Hawkeye diagnostic live date
Thanks guys
It has finally started. I needed to bleed it for a while by depressing the pedal 5 times. I will drive it a long distance and observe it. |
good to hear
