![]() | Home > Maintenance & Modifications > bolts |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
The ones that would normally hold the tie-down eyes or JATE rings if fitted?
On microcat it varies between M10 x 105 and M10 x 120 depending on year! although the chassis arn't any wider. I'd go for M10 x 120, you can always chop the end of the bolt down if it seems too long. The larger bolts that hold the panhard rod bracket (And some steering guards use these bolts on both sides... one of mine does) are 1/2" UNF x 6.5"... you need a spacer on the non-panhard rod bracket side to take up the slack on some guards, part # NRC5627 |
Cheers Jim, perfect
