Home > Maintenance & Modifications > bolts
BigMike
bolts
Does anyone happen to know the size and length of the two bolts which go through the front of the chassis to attach a steering guard/winch bumber etc? I can't check as mine is at the dealer and I want to upgrade the current ones. Is the ones which fit horizontally. I'm not bothered about the rear points, just the fronts as my winch bumper uses them as well as the steering guard.
Post #71486 18th May 2011 12:49pm
The ones that would normally hold the tie-down eyes or JATE rings if fitted?
On microcat it varies between M10 x 105 and M10 x 120 depending on year! although the chassis arn't any wider.
I'd go for M10 x 120, you can always chop the end of the bolt down if it seems too long.
The larger bolts that hold the panhard rod bracket (And some steering guards use these bolts on both sides... one of mine does) are 1/2" UNF x 6.5"... you need a spacer on the non-panhard rod bracket side to take up the slack on some guards, part # NRC5627
Post #71514 18th May 2011 4:19pm
BigMike
Cheers Jim, perfect Thumbs Up
Post #71515 18th May 2011 4:26pm
