Home > In Car Electronics > Relay chatter in TD5 - likely cause?
DC101
United Kingdom 2005 Defender 110 Td5 CSW Zambezi Silver
Hi,
Any advice please!
My 110 TD5 is currently off road suffering a couple of small woes, and I haven't used it for 2 weeks. Came back tonight to hear a loud relay chatter coming from under the nearside wing, to the front. This would clatter for a few seconds, and then alternate with a further chatter coming from inside the car, which I traced to a brown relay in front of the gear stick.
I presume it's an alarm issue, as in removal of the relay the alarm rather pathetically went off! i didn't try starting the car and neither did the central locking[img] work. I've disconnected the battery to stop the chatter.
Any tips on a way forward, at the very least I need to get my car over to the garage next week.I suspect I'll need to get a bit charge into the battery, too...
Thanks [/img]
Post #762950 11th Mar 2019 10:58pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
A couple of things to try
Possibly a low battery issue. Pop it on a charger and see if that helps.
If not
Then take the bbus off as it could be that the battery in the bbus is shot
Post #762993 12th Mar 2019 9:26am
DC101
Thanks Chopcat. I’ll charge the battery and see if that helps.
I’ve read a bit about the BBUS and will look further to see how to take it off. I presume it’s somewhere around the headlamp unit?
Pointers welcomed!
Post #763049 12th Mar 2019 3:20pm
