![]() | Home > In Car Electronics > Relay chatter in TD5 - likely cause? |
| chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 414
A couple of things to try
Possibly a low battery issue. Pop it on a charger and see if that helps. If not Then take the bbus off as it could be that the battery in the bbus is shot |
| DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 271
Thanks Chopcat. I’ll charge the battery and see if that helps.
I’ve read a bit about the BBUS and will look further to see how to take it off. I presume it’s somewhere around the headlamp unit? Pointers welcomed! |
