Home > Puma (Tdci) > Seat wiring spec
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Seat wiring spec
Does anyone know the specs for the heated seat wiring? I have ditched the heated seats and am considering using the wiring for something else but just wanted to check what sort of load it can handle, presumably it has a relay as I’m guessing heating takes a fair bit!
Thanks in advance😉
Post #761921 4th Mar 2019 8:30pm
Martin
Site Admin
No relay, directly switched by the dash switches.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #761932 4th Mar 2019 9:43pm
Clive
Just to add to Martins comment above, the Td5 seat heater circuit is fed from a single 20A fuse. (Same seat heaters.)
Post #761982 5th Mar 2019 8:58am
Pinky
Thanks
Post #761986 5th Mar 2019 9:36am
Martin
Site Admin
Same with the Puma, there's a common 20A fuse supplying both switches.
However take care adding new loads as there is a "weak" link in the ground path, there is only a single 0.5mm² cable acting as the ground for both seats (see below).
2015 D90 XS SW
Post #761991 5th Mar 2019 10:05am
Clive
Earth side "smoky fuse" - nice touch Shocked Laughing
Post #761994 5th Mar 2019 10:24am
