![]() | Home > Puma (Tdci) > Oil leak help |
| Scrawf Member Since: 24 Jul 2016 Location: Matlock Posts: 25
Isn’t that just below the oil filler cap? Have you filled her up recently and missed the hole?
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751
It is below the filler but unfortunately not just miss filled. Had the engine steam cleaned to see what was happening. From what I've read the camshaft carrier does not have a gasket, just sealant. I'm wondering if this has sprung a leak??
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
vacuum pump oil leak
https://www.defender2.net/forum/topic51106.html |
Thanks but I don't think it is as higher up the engine. I checked around the pump and all dry.
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
while ruuning your engine remove one end (air inlet side) of the PCV hose and check you get blowing air/gas Puma 110" SW
| FinnSmith Member Since: 03 Dec 2019 Location: cheshire Posts: 4
Hi, I have the same issue? just wondering if you know what is it and how much it is to fix? |
So I decided not to fix it as it was going to be expensive as you've got to take so much out to get to it. About a grand in the end. It's not enough oil dip down in my case. I simply spray a can of degreaser over that side of the engine and wash off with the hose once every 3 or 4 months and pre-MOT.
If you do decide to get it fixed please keep me posted as I'd eventually like to do it. J |
Do you know what causes the oil leak? such as what seal/gasket or whatever?
