Home > Puma (Tdci) > Oil leak help
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Oil leak help
I've got a leak in the engine and would appreciate help understanding it a bit better. It's by the front cylinder on the near side.
I had the engine steamed clean as unsure of where it was leaking. Drove a couple of hours and oil appears to be leaking where I'm pointing and getting oil on top of the black plastic air intake manifold.
It seems to be above the cylinder head gasket so I'm wondering if its the camshaft carrier to cylinder head?? I've not worked on an engine with this style of head they only have a cylinder head gasket and rocker box gasket....
I'm assuming you have to remove the camshaft, valve springs etc so have to take the head off anyway??? It's looking like a chunky job.
Is this a common oil leak and if left will it cause additional problems.
Ideally, I need to do a 2 hour, either way, trip before taking it off the road. I think it's been like it for a while so as long as engine oil topped up ok? It's not bad enough to have oil dripping down off the engine.
Post #761713 3rd Mar 2019 5:15pm
Scrawf
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Tamar Blue
Isn’t that just below the oil filler cap? Have you filled her up recently and missed the hole?
Post #761816 4th Mar 2019 9:42am
boxoftricks
It is below the filler but unfortunately not just miss filled. Had the engine steam cleaned to see what was happening. From what I've read the camshaft carrier does not have a gasket, just sealant. I'm wondering if this has sprung a leak??
Post #761819 4th Mar 2019 9:55am
dorsetsmith
Post #761836 4th Mar 2019 11:33am
boxoftricks
Thanks but I don't think it is as higher up the engine. I checked around the pump and all dry.
Post #761839 4th Mar 2019 11:38am
MK
while ruuning your engine remove one end (air inlet side) of the PCV hose and check you get blowing air/gas Puma 110" SW
Post #761857 4th Mar 2019 1:47pm
FinnSmith
United Kingdom 2009 Defender 90 Puma 2.4 SW Corris Grey
Re: Oil leak help
Hi, I have the same issue? just wondering if you know what is it and how much it is to fix?
Post #804581 3rd Dec 2019 1:08pm
boxoftricks
So I decided not to fix it as it was going to be expensive as you've got to take so much out to get to it. About a grand in the end. It's not enough oil dip down in my case. I simply spray a can of degreaser over that side of the engine and wash off with the hose once every 3 or 4 months and pre-MOT.
If you do decide to get it fixed please keep me posted as I'd eventually like to do it.
J
Post #804584 3rd Dec 2019 2:19pm
FinnSmith
Do you know what causes the oil leak? such as what seal/gasket or whatever?
Post #804585 3rd Dec 2019 2:23pm
