Home > Maintenance & Modifications > NAS STYLE BACK STEP
Page 2 of 2 <12
fekete
Hi Neil, really easy mate took me about 1 hour....the only problem i had is there is a bar that slips between the step and the chassis i had to cut about 1" off the end for it to fit, where the other step fitted to the chassis the bit it screwed into pertrudes on the chassis a few mill you could file it down i just cut the bar... hope this help Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #71695 19th May 2011 6:43pm
mse
The first one was a pig and was sent back
The second was was easy peasy - nothing required other than bolting up ISTR - Unless the kit has changed, i had to reuse the bottom x-member end bolts and a spacer from the kit. Take it easy on the bolts and im sure you wont have the right size to do up the external black cross members bolts...well i didnt and no-one i knew did, but i do now! Mike
Post #71717 19th May 2011 10:20pm
NCTT
Chees chaps , lets wait and see next week
Post #71727 20th May 2011 7:32am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
The original outer bolts that you use to fit the nas step are torx, the inner one can't be got at once the NAS step is in place as it's behind the tube of the step remember to change them ones to Hex heads. Thumbs Up
 Original Member Pie n Pea Club.
110 HCPU Tipper
Post #71734 20th May 2011 7:59am
NCTT
AHHH RIGHT , LOOKS LIKE ID BETTER PURCHASE SOME HEX HEADS
ANY IDEA,S WHICH SIZE ILL NEED ?
HMMM
Post #71754 20th May 2011 10:18am
NCTT
hang on im confusing myself , ive got a standard metric socket set , BUT the bolts on the back are like big alen keys ? what are these called , ive got to buy some of these ?
please excuse my ignorance guys ?
Post #71757 20th May 2011 10:36am
fekete
Thats all they are 14mm alen keys.... the rest that came with mine was standard socket set heads Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #71759 20th May 2011 10:56am
mse
Thats what i was saying Wink the central 2 are big allen keys and the out (top ones, my mistake its been a long time) you use the original torx ignore the kit bolts. Mike
Post #71760 20th May 2011 11:07am
NCTT
ahhhh that makes sense , perfect cheers men !!
Post #71762 20th May 2011 11:24am
willy eckerslike
On the outer fixings left and right you could use the original torx bolts x 4 but you will find that two of them cannot be got at to tighten because the Torx heads are behind the tube, hence two standard or stainless bolts needed if they didn't come with the kit. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #71765 20th May 2011 11:34am
NCTT
Top men , cheers ill let u know how i get on
taaaaaa
Post #71769 20th May 2011 12:38pm
mse
When i fitted mine you only had to remove the one require for fitting (top) - so you can leave the bottom in place...thats what i did - this would only be a problem if you were going to remove the seat stuff which from memory those bolts hold to the x-member.
There is a way to get at the lower torx bolt when fitted if required (never needed) get the small adaptor insert, locate it, clamp in place, and then undo the rear nut Thumbs Up Mike
Post #71772 20th May 2011 12:47pm
NCTT
ahhh yes that makes sense .
cheers............
Post #71800 20th May 2011 3:47pm
Page 2 of 2 <12
