![]() | Home > Maintenance & Modifications > NAS STYLE BACK STEP |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
The first one was a pig and was sent back
The second was was easy peasy - nothing required other than bolting up ISTR - Unless the kit has changed, i had to reuse the bottom x-member end bolts and a spacer from the kit. Take it easy on the bolts and im sure you wont have the right size to do up the external black cross members bolts...well i didnt and no-one i knew did, but i do now! Mike |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 ![]() ![]() |
Chees chaps , lets wait and see next week
The original outer bolts that you use to fit the nas step are torx, the inner one can't be got at once the NAS step is in place as it's behind the tube of the step remember to change them ones to Hex heads.
![]() ![]() Click image to enlarge Original Member Pie n Pea Club. 110 HCPU Tipper |
AHHH RIGHT , LOOKS LIKE ID BETTER PURCHASE SOME HEX HEADS
ANY IDEA,S WHICH SIZE ILL NEED ? HMMM |
hang on im confusing myself , ive got a standard metric socket set , BUT the bolts on the back are like big alen keys ? what are these called , ive got to buy some of these ?
please excuse my ignorance guys ? |
Thats all they are 14mm alen keys.... the rest that came with mine was standard socket set heads
Thats what i was saying ![]() |
ahhhh that makes sense , perfect cheers men !!
On the outer fixings left and right you could use the original torx bolts x 4 but you will find that two of them cannot be got at to tighten because the Torx heads are behind the tube, hence two standard or stainless bolts needed if they didn't come with the kit. Original Member Pie n Pea Club.
110 HCPU Tipper |
Top men , cheers ill let u know how i get on
taaaaaa |
When i fitted mine you only had to remove the one require for fitting (top) - so you can leave the bottom in place...thats what i did - this would only be a problem if you were going to remove the seat stuff which from memory those bolts hold to the x-member. There is a way to get at the lower torx bolt when fitted if required (never needed) get the small adaptor insert, locate it, clamp in place, and then undo the rear nut ![]() |
ahhh yes that makes sense .
cheers............ |
