![]() | Home > Technical > Td5 springs on a Tdi |
They're all completely interchangeable. I fitted a set of take-off 2016 springs and shock to my old 1992 90 and it was a straight swap. Darren
Alf_B Member Since: 17 Dec 2016 Location: Chelmsford Posts: 7 ![]() ![]() ![]() |
Oh perfect, thanks for the speedy reply!
Are the 110 rear springs not different from the 90 rear springs? Diameter? Roel
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
Yes, but not year dependant.
110 Tdci will fit 110tdi 90tdi will fit 90tdci |
Fortunately mine's a 90. One last thing, has anyone had any experience with spring isolators? Do they result in a bit of a lift? Or make any difference at all regarding cabin volume?
Isolators are generally a good thing, although they're designed to reduce harshness rather than noise. They do provide a small lift, in the region of 10mm, but you'd be hard pressed to tell without a tape measure.
This is my 90 following installation of new suspension including D1 isolators on the rear and D2 ones on the front: ![]() Click image to enlarge You can see the full details of what I installed HERE. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
