Home > Technical > Td5 springs on a Tdi
Alf_B
United Kingdom 1996 Defender 90 300 Tdi SW Corris Grey
Hi,
I've had a quick look but can't find a definitive answer - I understand shocks between Tdi and Td5 are not easily interchangeable (without some modification), but are coils at least universal?
Any help would be massively appreciated,
Cheers,
Alf
Post #760840 26th Feb 2019 3:17pm
They're all completely interchangeable. I fitted a set of take-off 2016 springs and shock to my old 1992 90 and it was a straight swap. Darren
Post #760841 26th Feb 2019 3:23pm
Alf_B
Oh perfect, thanks for the speedy reply!
Post #760843 26th Feb 2019 3:34pm
roel
Are the 110 rear springs not different from the 90 rear springs? Diameter? Roel
2003 90 Td5 (2009-now)
Post #760920 27th Feb 2019 6:29am
landy andy
Yes, but not year dependant.
110 Tdci will fit 110tdi
90tdi will fit 90tdci
Post #760935 27th Feb 2019 9:18am
Alf_B
Fortunately mine's a 90. One last thing, has anyone had any experience with spring isolators? Do they result in a bit of a lift? Or make any difference at all regarding cabin volume?
Post #760974 27th Feb 2019 12:43pm
Isolators are generally a good thing, although they're designed to reduce harshness rather than noise. They do provide a small lift, in the region of 10mm, but you'd be hard pressed to tell without a tape measure.
This is my 90 following installation of new suspension including D1 isolators on the rear and D2 ones on the front:
You can see the full details of what I installed HERE. Darren
Post #760986 27th Feb 2019 1:20pm
