Home > Td5 > 2003 defender td5. Smoke
divethedeep
United Kingdom 2003 Defender 90 Td5 HT Arles Blue
Hi all
Owned this defender for 10 years now
Never fails an mot
Loads of black smoke on hard acceleration but clears
Any ideas ?
Post #760665 25th Feb 2019 10:15am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Sounds like over fuelling, has the wagon had a remap? If not it could have a slight boost leak. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #760668 25th Feb 2019 10:36am
divethedeep
Just wanted to add. If landrover has sat ideling for a length of time smoke seems worse
Post #760682 25th Feb 2019 12:26pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
It's also possible:
1. MAF issue
2. copper washer at the injectors
3. injector wear and tear
4. turbo issue
5. driver demand (throttle pedal issue)
6. leaking turbo hoses
7. stuck EGR
8. intercooler requires a flush or replacement
9. oil in the ECU From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #760683 25th Feb 2019 12:27pm
landy andy
Has it always done this? Just started? Worse when hot/cold?
Have you tried driving it with MAF disconnected?
Checked the air filter?
Andy
Post #760741 25th Feb 2019 7:33pm
OsloBlue
The fact that it gets worse the longer you idle sounds like a temperature issue. Is the smoke having a blue tint? Wheres your coolant level? I'm on IG: https://www.instagram.com/osloblue42/
Post #760756 25th Feb 2019 8:29pm
divethedeep
Andy
It’s had a new maf fitted. (Genuine) Don’t know about cold as drive carefully when engine cold but definatlly hot
New air fitted a month ago
Post #761122 27th Feb 2019 10:21pm
landy andy
Could be a leak in the intercooler or its hoses. They show up worse once they have go warm, as they become softer.
Post #761125 27th Feb 2019 11:02pm
mturri
 2006 Defender 110 Td5 CSW Bonatti Grey
Also check your turbo-to-intercooler & intercooler-to-intake manifold hoses for internal delamination (causing air deprivation under medium to high boost conditions).
Have access to live readings via Nanocom or similar? 24 yrs of Td5 ownership
D110 Td5 MY06 fully tuned up
ex-D2 Td5 MY04 Auto
ex-D110 Td5 MY00
ex-D2 Td5 MY00
ex-D2 Td5 MY99
ex-D1 300Tdi MY89
ex-D90 200Tdi MY87
Post #761127 28th Feb 2019 3:31am
